Jackstands?
FXR1969
Loganville ga
Does anybody use 6x6 or 8x8 wood blocks for supporting there trucks while working on them?
search said use 2 5-6 ton stands, just wondering!!
74M35A2
313
Livonia, MI
I saw something interesting along these lines I wanted to pass along. It was not really easily adjustable, but did look to be awfully strong and low cost. Along the lines of a log cabin made from 2x4's. Check under front of the 1/2 M923A2 I picked up for my trailer project:
dmetalmiki
2,026
London England
I use comercial vehicle jack stands after Iv'e hoisted the truck to the required hieght with my fork lift. I the fork truck in situe for safety and the tynes are also then suported with lorry stands.
73m819
319
gainesville, ga.
I use 4x4, 6x6, 4x6, 2x8, to crib and support stuff that I am working on
171
Chaska, MN
i saw something interesting along these lines i wanted to pass along. It was not really easily adjustable, but did look to be awfully strong and low cost. Along the lines of a log cabin made from 2x4's. Check under front of the 1/2 m923a2 i picked up for my trailer project:
jenga!!!
motorolanut
Glenwood WV
I have heavy duty jack stands but ALWAYS used cribbing blocks 6x6 on heavy vehicles (2 1/2, 5 tons, farm tractors, dozers. Blocks are more forgiving and less likely to tip over when wrenching hard.
11Echo
91
CT W. R.
Blocks are a good idea. I usually skip that step when using these jackstands as I leave the truck hooked to the bridge crane.
azteclizard
Yuma, AZ
i welded up some scrap into some makeshift stands.. before yall go on about them failing... ive had a single set holding up the front on my m54 for the last year and 1/2 after i pulled the front axle and sprins for my bobbed m52... still holding.. and thats through some hellaious pueblo west winds, snow storms, monsoonish rains, and me crawling on, over, and through the truck pulling parts as needed..
