jerry can mounting
maddawg308
734
Front Royal, VA
I think they would go inside the bed. It's the only place I can think of that makes sense. The rear tailgate makes a little sense, but then you can't fold the tailgate down.
85-m1028
costa mesa ca.
do the mounts just have a base with a strap over the top? "like an m715" or is there a different set up, maybe one that could be locked??
ONTOS66
Franklin, NJ
Jim, the photos came through fine. Thanks. I saw a truck sailing down the road a few weeks ago with jerry cans mounted on the sides, but couldn't tell how they did it. This might have been the answer. Great idea.
BKinzey
Hollywood, CA
I'd suggest 2 antenna mounts side by side just to be sure :wink:
For an M1009 I'd also mount it on the tailgate for less of a chance to whack it on something. For those of us who are Belt & Suspenders type maybe look into fabbing up a brace from the inside as well.
dilvoy
25
San Francisco, Ca.
The anntenna install kits for the CUCV's have some reinforcment brackets that acutally attach to the inner panel and reach through holes drilled into it to support the outer skin of the vehicle. It might be a worth while addition due to the weight of a full can of fuel.
