jp-8 and wmo in 6.2.s military test
oddshot
119
Jasper, Georgia
I'm glad to see that they at least gave this a test. The Military generates a LOT of waste lubes. Its nice to see that somebody was doing some thinking.
Although I'm very glad to have this resource, unfortunately, it really wasn't much of a test.
Page 5:
"Used Oil Preparation:
426.7 gallons taken from 81 vehicles as directed by Army Oil Analysis Program
Mixed with stirrer and recirculating pump, 6 hours
Sample collected and analyzed immediately after mixing
All used oil filtered though 25n Fleetguard FF-202 fuel filter"
That's a just 25 micron fuel filter. Most home blenders filter down to 1 micron.
They also didn't heat the WMO or cut it with anything before filtering. WMO blenders/users have proven over and over again that heating the WMO or cutting it with gasoline before filtering helps the filtering process.
Also interesting is that there is no mention or thought of running their WMO stocks through a centrifuge system before blending and use.
Running the WMO through a smaller sized filter or a decent centrifuge would have given it a fairer test.
I'll have to do some digging to see if they did the follow-on field and emission testing.
Beyond Biodiesel
37
Prescott, AZ
I agree with much of what oddshot had to say, but we have to keep in mind that the test was conducted in 1998, long before anyone was blending solvents with waste oils, so much has been learned since. However, I also agree with him that in light of new developments in waste oil processing, and also knowing that the military has "one fuel for the battle field," which is JP-8, which is fairly light, then it could be blended with waste oils as high as 50%, left to settle for a week to a month, then filtered down to 1-micron, then centrifuged, and they would have a reasonably good fuel that would run on almost any diesel engine with little trouble. However, other findings suggest that direct injected (DI) diesel engines with turbochargers, such as the multifule engine burn waste oil blends more reliably than the old N/A indirect injected (IDI) diesel engines, such as the 6.2/6.5L diesel engines.
Jeepsinker
454
Dry Creek, Louisiana
Well yeah I'm aware of that, just wanted the opinion of some of you guys about it compared to others. Maybe it isn't as good as something else, or maybe it's really great. Idk.
Beyond Biodiesel
37
Prescott, AZ
JP-8 will need some oil in it if you want your engine to last; however, it is my understanding that the military runs all of their engines in the battle field on JP-8, and they run fine on it.
oddshot
119
Jasper, Georgia
Have you any experience with it used as a cutting agent for WMO? I'm guessing it is about exactly as effective as kerosine?
I do. I was given a very large quantity in the autumn of this year and have been blending with it since.
Your guess is correct, Jet 8 and Jet A are mostly kerosene, as opposed to Jet B which is a naphtha-kerosene blend.
I'm having very good results with it. Even during the coldest weather up here in the hills I had good starts and good cold performance. I haven't checked my mpg's in a while but I don't expect that they've changed much one way or the other.
Jeepsinker
454
Alright. I was given some as well and didn't want to waste it if it wasn't a good blender. I'm going to start blending and settling WMO soon but don't have enough saved up yet. I've only got about 25 gallons saved in a tote that's been settling for a couple months now with no cutting agent in it.
Beyond Biodiesel
37
Prescott, AZ
WMO that has not been thinned does not settle. If you are going to use JP-8 as your thinning agent, then I would recommend a 50% ratio, and if you do not have a centrifuge, then settling for a month to 2 months is best.
oddshot
119
Jasper, Georgia
Water and heavier material will settle or separate to the bottom of lighter waste oil. Oil and water do NOT mix ..or "blend". Go here for a simple explanation: http://humantouchofchemistry.com/why-oil-and-water-do-not-mix.htm
If you heat your waste oil, water and heavier sludge will settle or separate faster.
If you blend your waste oil with a thinning agent and agitate it, mechanically or with compressed air (sparging), it will settle or separate faster.
Iceman3005
97
Holt, MI
I work with fuels on a daily basis, jp-8 or jet fuel is identical to kerosene, only difference is the jet fuel is filtered about 20 times before it is sold to the loading rack facility.
Iceman3005
97
Holt, MI
I was up to a 70% wmo and 30% #2 diesel (pump diesel fuel). it ran fine but starting to lose a lot of power. I should have been cutting it with kero or gas. Thanks for posting the article!
camp9
9
Yooperland, Mi
I've had good luck with the same ratio, but in the winter I'll change over to #1 or Kero.
Markmoraes
Anchorage, Alaska
I have run probably 800 gallons of JP-8 thru a 6.2 and my 7.3 in my Superduty, never have had any problems. I have also know many others who have run it with no problems. just have had to filter it, as it was waste JP-8
bobbywalter
houghtonlake mi
www.dtic.mil/cgi-bin/GetTRDoc?AD=ADA349754
I found the link above of a study the military did to dispose of wmo in 6.2's as well as other diesel motors and wanted to share. It's a pdf so copied the link to this hope it works.
Page 5:
All that data does for me is confirm that running used oils, with some proper preparation, is viable over the long haul.
on edit:
dang it...i fawgged up my perfect post count on this....you bastages tricked me....
