Jump start
Dhjmd
Morton IL
So...was just thinking...I have a M923, four batteries, 24V. I also drive a Dodge with Cummins, 2 batteries, 12V. Could I wire in a NATO slave to the Dodge so that I could easily connect to the slave on the M923?
603hellmutt
New Hampshire
No, but yes. You would need to make the slave plug receptacle achieve 24v which would require wiring the 2 battery's in the Dodge to make 24v. Though I'm not sure if it will effect the Dodge. Best of luck
MtnSnow
14
NSL, UT
To jumpstart from your Dodge with two 12v batteries that is supplying 12v to the dodge truck you will need to use two sets of jumper cables and hook them up to the primary pair of batteries in the 923 hooking the cables up in standard 12v (so your supplying 12v to each battery from the Dodge's 12v)
dmetalmiki
2,027
London England
Absolutely not. You need the batteries wired in series for 24volts and they are already wired for 12 volts in parallel. You would short them out trying to do both circuits at the same time.
74M35A2
315
Livonia, MI
Way easier to simply get 2 new group 31 batteries for $100 each for the 923 and be done with it (not have to jump it). You can boost at least half of the 923 battery bank with 12v off the Dodge while cranking the 923, but would need to be a conventional jumper cable connection to 1 of 2, or to 2 of the 4 M923 batteries, and it will help 50% which can be enough to be the difference between it firing over or not.
