Viper350
- 1
- 8
- Richmond, Va
The witch's brew described above (ATF & Kerosene) works. Put several ounces in each cylinder and wait a day or two. Do not put the plugs in. Work the engine back and forth slowly w/ a breaker bar. Once it frees up, use a ratchet bar to turn it over in the direction of normal run. Watch the valve train and make sure all rockers/valves are working and returning to full seated (closed) position. Clear the cylinders of the witches brew. (small siphon vacuum) change oil, fresh plugs, check coolant, fresh batteries, fire in the hole, - I bet it starts. Then start ordering replacement panels.pull the plugs and pour about 2 tablespoons of Marvel Mystery Oil or PB Blaster in each cylinder, let it soak for a few days, you can also use a 50/50 mixture of ATF and kerosene, if the block wasn't full of water and the oil was good, it's probably stuck in the top end.
