Just bought my deuce, first had a ticking noise, now its knocking
oreo9688
New York
Just drove my new duce home and on the drive after a while I can here a faint ticking, I'm hoping it's not the engine but it sounds like lite knocking when costing or letting off the gas at higher speeds, basically just wondering if there is anything else that can sound like this thanks 😅
swiss
960
Oakwood, Ga
You are going to have a million issues to troubleshoot, research, and then fix. These are not new cars :)
First thing is you have to become familar with the vehicle so you know what is normal and what is not.
I would recommend first checking all fluids, grease everything and perform all maintenance. You have started on a long an lifetime journey. Get ready and dont panic.
Barrman
2,245
Giddings, Texas
They make a lot of noises that take a while to get used to what is normal and what isn’t. Are you wearing hearing protection? That is a must and also makes things sound totally different.
Do you have good oil pressure?
Look at your hood hinges at idle. They tend to get loose and bounce like crazy. Then running down the highway they look still and sometimes will start popping around at a specific to your truck speed.
Air compressor belt is something else that will sound like knocking if it is loose at certain rpms with the compressor pumping. Other times when the compressor isn’t pumping but still turning there will be no noise at all.
Try and wiggle your fan front to back. If you get movement, then the water pump could be knocking around on you.
What about your rear axle dog bones? I had one break on my Gasser M35 one night. Knocking, thumping and just chaos I couldn’t figure out until a car got behind me and I saw smoke in the mirror.
I just tried writing some of the things I have experienced.
oreo9688
New York
Thanks for the info,I did check dog bones before I left they seemed alright also the sound is definitely coming from the engine compartment and is in frequency with the rpm, I also tightened the belt before we set out but I will definitely re check that and the hinges,oil level and pressure was good so I'm hopeful that's at least a sign that it's not what I thought it was, definitely have a bit of work to do and learn.
oreo9688
New York
Thanks for the advice,I definitely have quite the learning curve ahead,I have a buddy who's a diesel mechanic that's going to be in town I'm going to wait to see what his take is on it before I do something major,fr now just fix things.
glcaines
2,827
Hiawassee, Georgia
Are you sure the ticking sound is from the engine and not from the transmission? Do you hear the ticking while the engine is running, but the truck is stopped? I recovered an M35A2 from Fort Indiantown Gap, PA to North Georgia, years ago. The whole way home I heard a distinct ticking while in 5th gear, especially when letting off the accelerator or going downhill at high speed. After arriving home and only a short while later, my transmission disintegrated while driving. The transmission was full of scrap metal. A takeout transmission from Tony Wright was required. No more ticking. These trucks make a lot of strange noises. It will take time to know what is normal and what is not.
oreo9688
New York
Valve tappets can make a ticking sound in step with RPMs.
A bit loose valve is loads better than one too tight.
It is a full afternoon job to set them, but good training and worth it.
Thanks for the tip,I was looking in to it more today definitely a sound from the engine around cylinder 4 and at higher rpm cylinder one, I'm going to have a buddy who worked on Diesels a lot more then I have take a listen and see what he thinks,I hope your right and it's not something worse 😅
oreo9688
New York
I just picked up a truck with the multi fuel engine a little over a week ago and started hearing some ticking on the way back, wasn't that bad chocked it up to it being an old truck.well i was driving down the road the other day and my oil pressure just started to sink and then it started knocking and sounds like a freight train,it only seems to do this after it gets good and hot but it's definitely a problem, anyone with a similar experience?
  • Sad
Reactions: HDN
cattlerepairman
3,537
NORTH (Canada)
Knocking is never good, especially when the oil pressure drops with it.
If you just picked up the truck, you likely planned on servicing it anyway. How do you feel about dropping the oil pan and checking main and rod bearings? Chances are, you find one or more worn. You can put new ones in from below....
A set of main and connecting rod bearings will set you back around $200.
Also, update the connecting rod bolts while you are in it! The old style (hex) has a habit of leaving its post when not supposed to.
Here is one source for the 12-point bolts you want: https://www.farmlandtractor.com/i-157326-r401091706-white-oliver-connecting-rod-bolt.html?brand:6
Another: https://www.jensales.com/products/e...ard-waukesha-zetor-rod-bolt-hercules-478.html
This could be a cheap fix as opposed to engine removal and rebuild (don't get me wrong, it's fun, but it is also a rabbit hole. Ask me how I know).
You can always do a compression or leak down test to see whether the engine would benefit from new rings. That, of course, means heads come off, yada, yada.
Sent from my SM-G991W using Tapatalk
Valley Rock
Big wheeler cat peeler
938
OR
Like mentioned, drop the pan (not a big deal) give rods a visual inspection wiggle test, you may have just one or two that have a problem .
If you don't see or feel anything obvious, then start pulling rod caps and a couple main caps and see what you have .
You may get lucky and catch things before damage is done to the crank and get away with new bearings and oil pump .
But you're not going to know until you look .
The debris field within the pan and oil you drain out should be a great indicator of what you're dealing with .
There's no telling what the engine went through with previous owners, and maybe one of those rod bolts has loosened up on you .
oreo9688
New York
Thanks for the info about the bolts,I have a few suspicions based on what I know so far,1 the previous owner come to find out replaced the head gasket and could have done something incorrectly,2 like you mentioned something with the bearings and rods.the previous owner bought it and didn't use that much at all (compared miles from auction papers) but it might have been beaten on in service and sold as is and I'm just finding out these issues 🫤
oreo9688
New York
I definitely plan on dropping the pan and taking a look,I just pulled the old oil filter out of the trash so I can cut it open and check for shavings or anything abnormal,I'm sure whatever I find is going to be a project, just got to figure out how to find it.
cattlerepairman
3,537
NORTH (Canada)
@oreo9688 I started on mine by opting for a replacement takeout engine, rather than diagnosing and fixing my knocking, smoking one. Ya, right. I thought..well, before I drop the replacement engine (it was running ok) in, I should do the head gasket because there is a trickle of oil. Seeing I had the heads off, why not take the oil pan off and check the bearings...seeing that heads AND pan are off, would be silly to not pop the pistons out, do rings and bearings....you see where this is going?
The ability to say "STOP" is a gift!
