Just found a problem and a solution... for the horn malfunction on anM925A1
scootertrs
miami/florida
While doing the complete go through of my new truck, I noticed that the horn was not operational. If grounded at the horn relay it would work fine. If I wiggled the steering wheel, once in a while it would do its thing. Tracing the wires we found that there is a connector at the bottom of the steering column, inside the cab that even though it looked OK, the outer piece that grabs the prong of the wire going to the horn relay had broken off. We were able to reassemble the connector and put it back together and now I can get your attention... figured I would give something back to the guys that have given me so much help.
goldneagle
906
Slidell, LA
Mine had a loose screw that the ground wire was supposed to be attached to at the bottom of the column inside the cab. Had to install a larger diameter screw to get it to hold tight.
238
Las cruces nm
I just fixed my horn and it was a PITA. I ended up replacing everthing for the horn except the horn and solenoid. I put everything together and NOTHING. Then i took a break thinking about it. I finally figured out that the new diode i put in was bad as well. So i got a new diode and all is well. Finally i can make it go toot toot!
jwesley74
Englewood, FL
ANyone know the NAPA P/N for the air horn solenoid? Our M925 solenoid post broke, and is loose. Now being jiggled the horn will stick on. We have disconnected it for now. Need a new solenoid, but would like the NAPA P/N if anyone knows it.
scootertrs
miami/florida
Youu can do a geebaye search for 24v air solenoids. I picked one up for $12.00 (continous duty) for my a/c engine fan turn on project-ss rules do not allow for posting auctions
