Just ignore this
A059FMJ5.56MM
Charleston SC
Ok i am new and trying to see how things go. If your read this my M109 Shop van will not start for some reason. I am NOT repeat NOT a mechanic (or a good speller) but i got the truck for a good price and all last year it started fine. Winter rolled in and one day went out to start it and the Starter just goes CLUNK, like it hit a brick wall any ideas.
A059FMJ5.56MM
Charleston SC
Yeah tried that but didnt seem to work, a budy told me to get a volt meter and check what the batts were holding and what was reaching the starter. Then he said maybe the motor froze up and to try to turn it by hand. Front of the flywheel or use the teeth on the ring gear. (that meant nothing to me) so he talks me under the truck and says look for where the transmission conects to the motor...I found this little hole but no teeth just smooth. to get to the flywheel i would have to move the radiator there is only about a inch of space. You know picking up a big truck seems cool, but it should come with a warning label..IN fact GL should pu this on your bill...will cause you to make new friends, will cost lots of time and money, will make you learn stuff you never would have befor. I am sure i will learn tons with this in my driveway.
goldneagle
1,508
Slidell, LA
I would also check the connections to the battery and the main ground to the engine or frame. The connections could be loose or dirty. Carefully remove the clamps from battery terminals and use a wire brush or a brush designed for battery terminal.
A059FMJ5.56MM
Charleston SC
Pull start
I thought about this but i need two people for that task. My mechanic promissed to check it this week. If he starts it I will ensure whatever the issue is it doenst happen again. Just becauswe the truck is almost 40 years old doesnt mean it shouldnt work.
1,193
So, was that your M109 at the shop on RT3 near Sackets Harbor?
