JTugwell
- 3
- 0
- Pensacola, FL
well after spending a couple of hours the other weekend pulling my axles back straight with a tow strap, because the rods fell off the bushings i decided they probably needed to be changed.
i started on it tonight, and replaced the lower torque rods. i am going to tackle the uppers tomorrow. i just wanted to make sure i wasn't missing anything. i removed/replaced one at a time with the whole rod with new bushing already in it. i removed the brackets (i figured that it would be easier that way.). installed the brackets with the new bar on it, and tightened all the bolts down. after everything else was secure I tightened the nut that secures the rod end to the frame last. everything looks ok. i just wanted some expert opinons to make sure i didnt screw anything up. i will post some pics up later on tomorrow. the old torque rods were so bad that when i threw them an the floor the rod ends just fell out! out of all six only one was still good. it will definatly be good piece of mind knowing that my axles wont come loose again.![Very Happy :-D :-D](https://www.steelsoldiers.com/images/smilies/icon_biggrin.gif)
thanks everybody!
thanks everybody!
