D Foster
- 3
- 8
- Franklinville, New Jersey
I BELIEVE I AM HAVING A PROBLEM WITH MY K1 RELAY ON MY PDB, M107. I HAVE A FULL CHARGE ON THE BATTERIES AND WHEN GOING TO START MY PUSH BUTTON STARTER SWITCH JUST CLICKS. I WAS ABLE TO PULL THE K1 RELAY AND USED A JUMPER WIRE ON THE TWO VERTICAL PINS (NORTH/SOUTH) AND IT TURNED OVER AND STARTED. WITH THAT I THOUGHT I HAD A BAD K1 RELAY. WENT OUT THE NEXT DAY AND AGAIN ATTEMPTED TO JUMP K1 TERMINAL WITHOUT THE RELAY IN, THE STARTER/ENGINE TURNED OVER WELL BUT NOW WON'T START? MY CIRCUIT BREAKERS DO NOT LOOKED TRIPPED. IS THE K-1 RELAY 12 OR 24 VOLT? i KNOW THE STARTER WORKS OFF OF 24 VOLT BUT NOT SURE ON THE RELAY? I THOUGHT MAYBE THE START INHIBIT BUTTON BUT THAT APPEARS NOT TRIPPED (BREAKER CB79). ANY SUGGESTIONS WOULD BE APPRECIATED AND IS THE K1 RELAY A COMMON RELAY TO PURCHASE. THANKS
