Kats Circulating Heater Install Problem
asg13
wv
Took my truck to my local guy who works on it occasionally. He is having trouble with the parts provided to install it properly so he says. It comes with a tee for the return i believe, but the inlet. The hose on the truck is 1 1/4 inches. So i need a tee 1 1/4 on both ends with the nipple 3/4 inches so to speak. I know this is hard to follow. Hopefully someone has installed one of these in the cucv and can give a bit of direction.
rsh4364
15
greensprings ,ohio
I have a tank style heater also and plan to install as dependable posted,I have to fab up some mounting brackets for mine.The main thing with the tank style is the heater must be lower then the feed point.If you feed from lower radiator hose its really hard to install heater lower then that point.Im using a hotstart heater# tps151gt10-000,it has no check valve so it will flow both ways.So it should work when following dependables install link.When the truck is running coolant will flow from pass.side head thru block heater to heater core.But when motor not running the block heater is fed from heater core inlet and block heater outlet goes into coolant crossover to heat engine.Another way is feed it from bottom of radiator on drivers side by removing rad. petcock and adding a barb fitting in its place,then install a hmmwv coolant crossover,it has a port on drivers side you can tie into.But you still need block heater lower than the point feeding it.The nice thing about the Kim Hotstart units are they are rebuildable and have a built in thermo.heats block 100-120 degrees and turns off at 120.If your temps. rarely get down to -10 or below just install a temro freeze plug block heater,1000 watts. Friends don't let friends buy Katz.
cucvrus
10,427
Jonestown Pennsylvania
,then install a cucv coolant crossover,it has a port on drivers side you can tie into
Are you referring to a HMMWV coolant manifold? Like the one I sold you? I am trying to picture your Antarctic tundra design. You need to get the CUCV arctic grille cover also. :idea:
rsh4364
15
greensprings ,ohio
Yes the HMMWV crossover,my bad..I have the Jatonka grill cover.Thanks,Rick.
cucvrus
10,427
What ever a jatonka is? Sounds like a cardboard box that a Tonka truck came in. I am making a new grille cover for my Mule. I will preview it when it is complete. I am using genuine CUCV parts.
cucvrus
10,427
Be on the lookout for OHIO FNM7445 sporting the Jatonka bra winter cover. Is it snowing in Ohio already? If it is keep it there. the plows are not ready in PA.
