- 2,181
- 3,342
- 113
- Florence, SC
Wow, progress looks awesome!
Totally awesome , amazing craftsmanshipThanks guys, I’ll try and keep it up to date.
Is that alu or stainless?How are you tying the aluminum frame to the walls?
Just a quick couple of questions about the truck ! Do you have any kind of security/ camera system in your back yard? Or any big mean dogs? or you have guns in the house ? I wouldnt want to travel that far to get all skint up trying to relocate your truck when your done with it!Testing the motorcycle lift. View attachment 841661View attachment 841662Yes it’s going to hang out a little and I haven’t fabricated the track mount for the motorcycle instead I shifted all my work to the interior of the habitat. If your wondering about the bike it’s a Honda 125cc Grom that I changed all the plastics, also going to put some off-road tires on it. I chose it for the size and fuel mileage (100 mpg) my wife and I fit on it comfortably.
My solar panels stay on all the time which charges my house batteries in the shelter and those 12v batteries feed the 2 12v batteries on the truck and like you said for some reason that keeps the 2 24v batteries hot in the truck batteriesJump Starting the FMTV!
Yesterday I attempted to start my truck and the batteries are dead again, understandable they are 6 year old batteries. A quick trip to Sam’s club 4 new group 31C batteries and one of those small jumpstart boxes only 3.5”x1.5”x8” 12vdc. On the way home I thought maybe I can use the new jumpstart box connected to the 12v side of the batteries, with the understanding that you can actually charge all 4 batteries using a 12v charger. If you don’t believe me try it it works. Crazy enough hooked up that little jump box to the 12v side and it cranked right up!Turned it off and started it again. I’m sure others may know but I’ve never read it before and wanted to share the info.
.Yeah, anybody figure out the 12 volt parasite?
Ron knows about as much on the topic as anyone I've seen post. He's had some interesting perspectives.Yeah, anybody figure out the 12 volt parasite?
in the A1's.... seemingly not true based on recent discussions..... battery disconnect removes the micro charge for the ecu in A1's ... apparently ecu battery dies and they are not replaceable..... and/or you loose settings if it does not die from it.Ron knows about as much on the topic as anyone I've seen post. He's had some interesting perspectives.
There's the trans computer that is always on, but at the end of the day a battery disconnect solves all.
.Can't say, don't have an A1. Mine's an A1R with a battery disconnect. and it sure as hell safely stops the drain when the battery is disconnected. I also know that a battery disconnect works fine in an A0 truck. Want to test it? Go pull your battery cables for a day. Hook them back up. Truck works fine.
So you (or someone) are saying that an A1 that has sat with dead or no batteries installed for an extended time has a brick for an ECU as a result? Because that's likely over 90% of the A1's coming out of the various auction houses.
Agreed on some sort of tender (solar, 120v) combined with a balancer. But at the end of the day, it's still almost ALWAYS the 12v side that 'leaks" not the 24v side. Interestingly enough, the dual voltage Niehoffs are not "balanced" to begin with (note the output on the various sizes, always vastly higher on the 24v rail with only a couple exceptions). So I suspect it's not quite that simple. If the 12v side is inherently low on these trucks, you would expect the alt to push out more on the 12v output side (yet the reverse is always true by design).
Again, not my expertise, thus I mentioned Ron.
C.E. Niehoff Co. - Brushless Alternators - Commercial - Military - Mining - Construction
Generic Description Herewww.ceniehoff.com
btw: unless the truck is parked up in the arctic circle, four batteries is overkill, so there is little reason to ever replace four new batteries
dont remember which A1 or A1r.... whichever one or both has a battery in the ecu same as any home computer. There is several threads in here on trucks where they have had to replace the whole ecu cause battery in it was dead/going dead. Other users have pointed that this may be for the very reasons you indicate above as possible causation; while there is other threads that also point out that poor circuit board soldering of the Power Distribution Panel in a few years of the trucks may be part of it too.......
