Kerosene cut / thin ratios?
rolling18
77
Portland, OR
I was lucky to pick up a full barrel of Kerosene yesterday,
but could not find any recommendations on a ratio to thin WMO
using Kero.
how would this work pure??:cookoo:
1,178
100%, it's the same as diesel.
rickf
1,638
Pemberton, N.J.
isn't there a lubricity issue or does that not pertain to the multifuel? Kerosene is more of a solvent than it is an oil.
Rick
1,178
http://toad.net/~jsmeenen/fuel.html
Carbon Chains in Petroleum Products
The different chain lengths have progressively higher boiling points, so they can be separated out by distillation. This is what happens in an oil refinery -- crude oil is heated and the different chains are pulled out by their vaporization temperatures. (See How Oil Refining Works for details.)
The chains in the C[SIZE=-2]5[/SIZE], C[SIZE=-2]6[/SIZE] and C[SIZE=-2]7[/SIZE] range are all very light, easily vaporized, clear liquids called naphthas. They are used as solvents -- dry cleaning fluids can be made from these liquids, as well as paint solvents and other quick-drying products.
The chains from C[SIZE=-2]7[/SIZE]H[SIZE=-2]16[/SIZE] through C[SIZE=-2]11[/SIZE]H[SIZE=-2]24[/SIZE] are blended together and used for gasoline. All of them vaporize at temperatures below the boiling point of water. That's why if you spill gasoline on the ground it evaporates very quickly.
Next is kerosene, in the C[SIZE=-2]12[/SIZE] to C[SIZE=-2]15[/SIZE] range, followed by diesel fuel and heavier fuel oils (like heating oil for houses).
Next come the lubricating oils. These oils no longer vaporize in any way at normal temperatures. For example, engine oil can run all day at 250 degrees F (121 degrees C) without vaporizing at all. Oils go from very light (like 3-in-1 oil) through various thicknesses of motor oil through very thick gear oils and then semi-solid greases. Vasoline falls in there as well.
Chains above the C[SIZE=-2]20[/SIZE] range form solids, starting with paraffin wax, then tar and finally asphaltic bitumen, which is used to make asphalt roads.
All of these different substances come from crude oil. The only difference is the length of the carbon chains!
Now, If I were given a barrel of kerosine and I ran used motor oil regularly, I would use the kerosine to thin my UMO. How much? I personally add 5-10 gals of diesel or kero to 40 gals of UMO. Been doing this for quite some time. never had an issue yet.
1,178
An advanced search in the alt fuels forum for "ratio" will get you 54 threads. Some have some good info and advice.
rickf
1,638
Pemberton, N.J.
I know, I know, search is your friend. Search hates me! I can never seem to find the right phrase to enter. Thanks for the info, that will be reading for tonight.
Rick
rolling18
77
Portland, OR
That was my concern as well
Rick
ahh "advanced" search fergot about that one!:cookoo: I will do that today!!!
:ditto: not to mention the time it takes to read through all that to find the exact info you are seeking..
but thanks for at least answering my question!! [thumbzup]
Rick
1,178
An "advanced search" does sound highly intellectual and complicated, doesn't it...
Simply put, an advanced search gives you a few ways to narrow down the results you will get.
