Keyed ignition starter switch
nafshiel
Philadelphia, PA
Has anyone installed one of these units sold on eBay and can provide step by step instructions?
I realize it probably is plug & play, but not for me... :-?
Mouse over image to zoom
[h=1]MILITARY Hummer TRUCK PLUG &PLAY KEYED IGNITION STARTER SWITCH[/h]
hmmwv1
haines city fl
i went to the parts store and got a universial keyed ignition switch for $15 and wired it in,only 3 wires,battery feed,ignition power,and starter
Havok
Boston/MA
I have the keyed ignition you get off ebay. Its easy takes all of 15 minutes.
1 Unscrew the existing switch and pull it off
2 Reach under the dash and pull out the rest of it
3 pull off the wires and connect the wires on the new switch (gromets label what wires are which)
4 drill the hole opening to make it fit the new ignition switch
5 screw down the new one with the plastic washer they give you.
M543A2
10
Warsaw, Indiana
I simply put a keyed switch in the feed wire to the military ignition switch on my M series trucks. Off, no power to the military switch so it cannot be used to start the truck; key switch on power is sent to the military switch and it works as normal. Very simple installation! Only one wire to work with. I would assume the same concept would work on your truck.
Regards Martin
sermis
17
Temple, TX
I made my own from an old key switch I had in the shop and wires from a busted tail light so I would have the connections. Simple and helps with when I come out of a store or truck is on display. Never fails that when I go to town someone is in the truck taking pictures when I come out.
