Have any of you HEMTT/MK48/PLS owners ever converted to a keyed ignition switch? If so where did you get the switch and what was the part number. I want to do it but am having a little trouble trying to locate a switch the has the proper number of terminals on the back.
This is what they usually have stock. This is the exact same switch from Oreilly BWD#CS201 for $40. This is a keyed one from Oreilly BWD#CS114 but is short one connector on the rear of it. Any one have suggestions? I will be inspecting the back of my switch later today to verify if all 5 connectors are in use. If anyone has a wire diagram for the ignition switch that may be very helpful. I have searched for the wiring pinouts for the switch but can't seem to find anything. I looked at maybe a keyed switch for a HUMMWV but they only have 3 wires. I appreciate any help.
