KenzMan
- 0
- 0
- Cape Breton
So I got checking out the front end of my truck and noticed the driver's side wheel has movement up and down . I took everything apart to have a look at it and everything looks to be alright other than the steering knuckle being able to move vertically on the king pins . On the bottom there is the bushing and the plate , on the top there is the bushing with a steel puck in the middle of it and then the steering arm goes on top of that . The first pic is with the steering knuckle jacked up tight to the axle housing and with a straight edge across the top of the bushing I have a .022" gap . The second picture is with the knuckle hanging . I have no idea why I have a .022" gap . So my questions are , is there only the one puck on top or one top and one bottom ? and also how much total clearance to I want to have everything assembled properly ? The puck I have now is a little over 3/16" . I also have a bad oil leak on that side of the housing and I'm thinking this situation isn't helping that either .
Thanks in advance ,
Kenzie
Thanks in advance ,
Kenzie
