Large wire crimping
rtadams89
Phoenix, AZ
I need to crimp some (only 4) connectors onto 00 gauge wire and the standard method I find seems to be using a hydraulic crimper. I do not have a hydraulic crimper. Should I spring for a cheap hydraulic crimper and a hand operated hydraulic ram pump (maybe DIY the pump: https://www.youtube.com/watch?v=tbFKSy9oA0A) or can I get away with a set of crimping dies in my bench vise? Or perhaps there is an even easier/cheaper/better option I'm not thinking of?
juanprado
2,915
Metairie/La (N'awlins)
2 easier ways I have used if you have the solder type terminal is to use a propane torch and vise to melt the pellet. On the crimp terminals, I have used a sledgehammer against concrete. Once you verify a solid connection, then insulate with heat shrink tubing.
sigo
Lieutenant Colonel
400
Leavenworth, KS
The hydraulic crimper from harbor freight isn't too expensive and it works great. I usually solder and crimp my big terminals.
rtadams89
Phoenix, AZ
I was looking at that. I would need to get or make a hydraulic pump. I was also thinking about just getting some of the dies and using them in a vise.
sigo
Lieutenant Colonel
400
Leavenworth, KS
This is the tool I was referring to. It's self contained, no other pump required. It'll crimp your terminals with ease.
http://m.harborfreight.com/hydraulic-wire-crimping-tool-66150.html
Before I got this I used a vise, but I was rebuilding some battery cables and decided I wanted a cleaner more reliable crimp. This tool has lived up to my expectations, and four years or so later it still works. I don't say that often about HF tools.
319
Lieutenant
57
Michigan
I have this tool. Except for the dies being grossly mismarked, it makes a great crimp with very little effort.
rtadams89
Phoenix, AZ
Ahh, awesome, I hadn't seen that one before. I was thinking of the one which requires a separate pump. That seems like the best way to do it, and cheap enough.
MWMULES
349
DESOTO, KANSAS
I went to my local alt/gen rebuild shop and they crimped them for free. I then went to the closest donuts shop and brought them back a doz!
Cape Coastie
CWO4 ENG/MSS, USCG, RET.
528
124
Sandwich, MA
I use one of these at work for all my terminal connections for yacht battery cables. A quick whack with a 3 pound hammer and some shrink wrap and they never come apart. Does several different sizes. Not too expensive either. Good luck.
rtk
446
Lockport N.Y.
I use the same tool as Cape Coastie and it works great and is CHEAP , lasts forever . Use a little shrink wrap and you should be good to go . I made up a set of cable end for my military jumper set , worked out great .
tobyS
833
IN
Don't forget liberal anti-corrosion compound. It helps to lube the strands as they are compressed into place and then prevents oxidation that is especially a problem in DC circuits.
When I did heat rise testing for UL listing, we tried all kinds of anti-corrosion compounds (for affecting the electric carrying capacity). we found Vaseline was consistently among the best, but Noalox probably handles higher heats.
