LD & LDT465 Upper Limits
ocmechanx
Been finding alot of post on repowering dueces and 5 tons. And I was wondering why; low power, parts hard to come by, or just for fun?
I was figuring low power, and that led me to wonder what one of these engines would put out if PROPERLY modified, pyro, turbo, fuel settings, timming, ect.
They seemed to be a fairly robust engine with decent displacement, not sure if they are a low or high compression but that could be a problem I suppose.
So what would one of these engines put out without out putting?
hklvette
Christiansburg, VA
I would think that the amount of air that can flow through the heads would be rather low as a result of the strong swirling action of the intake ports. Also, the 22.5:1 compression causes more stress on the pistons, rods, bearings, and crank. Adding power won't help those items any.
Don't know anything myself about what adjustments are allowed in the IP, but I do know from reading here that pyro and sometimes boost are the usual additions before mods.
Trango
22
Boulder, CO
This is an old topic. Let me summarize:
LDT's don't take kindly to more power.
Transmissions are limited in gearing, both for number of gears and top speed
The trucks don't like to be driven at redline for tens of thousands of miles
You can turn up the power and add a pyro, and get maybe 180/500 HP/Tq out of the mill, all in a 13,500 lb package (still slow).
A repower is pretty much the only way to get a good top speed and reasonable power past 30-35MPh, especially up hills.
Stick around, and read some of the threads. Searching will also yield heaps of info.
Best
Bob
ocmechanx
Ok good to know, I actually have a M54 are there any major differences mechanically between those of the 2 1/2 tons or are they pretty much the same?
