JasonS
- 139
- 63
- Eastern SD
Who is using the LDS-427 turbo on their LDT and how do you like it?
They don't make much boost. If your planning to up the pressure in your engine then you need to go with a more modern turbo. There is a thread on the differences between the LDS and the LDT engines which really gets into the power differences and mods available to make more power.Anyone ever try and see how much boost they make?
I have an LDS 465 and am familiar with the differences, but this thread is referring to a 427...different animal. Jatonka and others say View attachment Scan0051.pdfView attachment Scan0054.pdfView attachment Scan0053.pdfView attachment Scan0052.pdf I truly hate this sites downloading tools ! OK here goes. David, if you had read the posts I referred you too you would have seen this posted. Since I like you I went ahead and spent an hour to download this again. The first and last pictures show the pages from the TM 9-2815-204-35 which is from the LDS-427 engine manual. The second and third pictures show the pages from the TM 9-2815-210-35 which is from the LDT-465 engine manual. You can clearly see that the LDS engine only makes 140 hp (gross) at 2600 RPM and 340 ft-Ibs (gross) torque at 1400 RPM with a compression ratio of 20:1 , using the Schwitzer 4-450 turbo (later ones used the 4-D).
The LDT-465 engine makes 205-220 hp (gross) at 2800 RPM and 440 ft-Ibs of torque (gross) at 2000 RPM with a compression ratio of 22:1 , using the Schwitzer 4-456 turbo. Basically the same as the 4-450 turbo. So you can see that the LDS-427 is not the high power engine with super turbo you think it is.
He said it was a minimum.That comes out to 1.7 psi, which is nothing...?
http://www.kylesconverter.com/pressure/inches-of-water-to-pounds-per-square-inch
