LDS 465 205 H.P
kaiser2help
East Freetown, MA
I was wondering if there was someone who could help explain to me on how to by pass the compensator pump on my multifuel engine. I only burn home heating oil or pump diesel. I was also wondering if that this procedure is not recommended. I guess that compensator is there for a reason. Help on the topic would be appreciated.
cranetruck
75
Meadows of Dan, Virginia
Please, do a search on this site, subject has been covered multiple times....access forum and use search function in the heading, keywords like "FDC", "bypassed", etc...
1,807
Not too many folks check the website help forum either. Perhaps listing this in the appropriate forum will generate more help.
cranetruck
75
If the compensator is not leaking fuel into the crankcase, there is no need to bypass it. Its function is to adjust the fuel delivery based on its viscosity (=BTU value) so that the engine power output remains the same for a given position of the "gas" pedal.
It has nothing to do with the engine's ability to burn a particular fuel.
It only works for the fuels listed in the TM and actually works against fuels like biodiesl and veggie oil.
Biodisel and veggie oil have about the same BTU value as gasoline, but has a higher viscosity, so the compensator lowers the delivery "thinking" that it is dealing with a higher BTU fuel. Hope that makes sense.
BTW, the TM 9-2815-210-34-2-1 lists the 1A engine as a 175 HP engine....that's why I was wondering about the title....
kaiser2help
East Freetown, MA
Thanks bjorn. I must have gotten my resources mixed up. I thought ldt was 175 hp & lds was 205 hp. The good thing is the crankcase oil does not appear to have any excessive diesel fuel smell or presence. Also were would one obtain the diaphram or seal for the FDC. aLso while were on the topic. This engine runs at 180 degrees. I would like to see 190 or 195 to allow proper expansion of the cylinders and assemblies etc. maybe this would help clear up the smoke a little.
cranetruck
75
No seal for the FDC, apparently metal to metal seal with honed surfaces.
The thermostat begins to open at 180°F and is fully open at 190 or so.
These engine rarily runs above 185. The engines are pretty efficient as is the cooling system....
Best way to clear up the smoke is to take the truck on a hard 50-100 mile run, the engine will love it.
kaiser2help
East Freetown, MA
Yes I have read somewhere that this infact uses a piston and a smooth honed cylinder surface. Hope this never wears out . You are right a good run cleans it right out. Read in that manual you mentioned and thats the right engine temp, 180. Thanks for the help.
