dmetalmiki
- 2,027
- 113
- London England
I never, in over 60 years motor engineering came accross such a 'Micky mouse' engine setup as confrontd on the M series vehicle Multifuel pumps,
Videos on utube perport to show 'How to' time up the pumps.
1 Guy states it does not matter where the engine front pulley mark is!
Another states " the pump is 180 degree out IF YOU SEE THE MARKED TOOTH in the window!!???
"Rotate untill you do NOT see the mark, Is correct"!! (MUPPET!")
Others point and poke at the screen while mumbling about this that and the other!
LOGIC. (decrees).
The front engine pully is set at MARK of the Particular engine installed. LDS
LDS 1 LDS 4651 LDT 465 1A etc.
The Fuel pump window pointer lines up with the mark on the viewable wheel under the pump cover.
The MARKED TOOTH in the Hydraulic Head window line up with the pointer.
NO!. of course not!!
.I carried all the above, And the COVER
(A pointless piece of metal junk!)***
on the COG in the pump PREVENTS the Hydraulic Head from being installed.!!
F Brilliant , So, My question, To the experts on this procceedure.
Why bother to have ANY timing marks at all?
Annoyed, Frustrated, and Just plain fed up.
I have everthing set up with all pointers alligned correctly, (And) the Hydraulic Head Can Not ( now*** ) be installed.
This procceedure SHOULD NOT be a guessing game.
Viz. Back off the engine, Insert the head when the prevention plate f off out of the way
Re-allign the pointers, Wrong!
Keep doing this one cog of the hyraulic head adjusted a time untill ALL popinters are lined up correctly. (By re forwarding the engine to the pully timing marks) And the injiction timing marks allighn.
As they should be per the T.M.s. (Hence, "Mickey mouse".).
LOGIC. (decrees).
