LDT turbo specs come in here!!!
Blackmagic94
9
Oro Valley/AZ
Ok lets discuss known factual info on the specs of the C/D turbos in here.
I want to know the following
Compressor MM size
Turbine MM size
Compressor A/R housing size
Turbine A/R housing size
Downpipe flange OD/ID
Compressor Map
ODdave
40
lansing michigan
I will go look, Not shure why my posts got deleted but we will try again......
I looked at a couple of spare "C" turbos I have and this is what i come up with.
Inducer wheel- 54mm 12 vane 2 stage
Exducer wheel- 66mm 11 vane
Marking in the exhaust reads 29, With what looks like an A behind it. I cannot say if this is an a/r ratio because I dont see a decimal point.
brianp454
11
Portland, OR
Do any of you guys have part numbers (such as for NAPA?) to allow me to pick up the rectangular exhaust flange and round exhaust ring gaskets? I'm hoping to get them locally rather than order them from one of the surplus places.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
The gasket size has been posted. Most turbo shops should have them. I think the turbo to manifold gasket is under $10 at that type of shop. The others should be just a standard "turbo exhaust gasket".
