Leaf Spring Bushing
USMC6062
St Augustine, FL
Does anyone know where to buy them, or has anyone replaced them? I bought a set of front springs and hangers the other day in case I want to bob my truck, but the bushings are a little loose and I might as well replace them before I put them in. Thanks, Alex
rosco
30
Delta Junction, Alaska
Check in your area for a spring/suspension shop that works on heavy commercial trucks. That is a common item that is often replaces when springs are re-worked. Check the pins too, for wear, but often its just the bushing.
Lee in Alaska
FSBruva
Marietta, GA
I would also check FLMV. They have a lot of parts that are not listed on their website.
Did you check Easternsurplus, Memphis or Alfaheaven?
Matt
USMC6062
St Augustine, FL
I sorta planned on checking with the heavy truck suspension place here in Jax, but figured that someone had a source for them or knew for sure what size they are. I would like to have them when I tear it apart that way I could go right back together. I'll check with some of the sources you listed. Thanks, Alex
Jones
Sacramento, California
If they're flush on each end and have a cross bolt that retains them, in a perfect world they SHOULD just drive out. Load them up with grease or penetrating oil and make sure there's no load on them, then go for it with a piece of pipe (to protect the grease fitting) slightly smaller in diameter than the pin, and a hammer.
The ones that unscrew will have a hex end to accept a wrench; though I've seen them mostly on Jeeps.
