Leaf spring re-arch
Tow4
626
Orlando, FL
Go to a spring shop. They can re-arc your current springs or build you a new set. I've had both done. If you are going to haul heavy, get new springs.
Bob H
159
That is what I was thinking, new set but how do they relate to M880's ! ton and a 1 & a 1/2 ?
1976/1977 Dodge W200 pickup with 3500 lb front axle (D44)
for reference my W400 with a 4500 lb front axle (D60) has 6 or 7 leaves under the main leaf. They are interchangeable between the two.
JC Whitney among dozens of other online sources has them, any spring shop can get or make them.
sf38a1
NW Florida
Best thing is to go to a Spring shop. I have done many re arch with a hydraulic press, added leaves, and complete rebuilt springs. Sometimes if you re arch and don't add a heaver leaf ,they will tend to flatten out over time. You will need new center bolts and New u-bolts. if you increase the leaves on the spring pack you will need longer u-bolts Have fun
