paulfarber
- 19
- 0
- Gordon, PA
Today I was shooting grease in the zerks and got to the forward read axle. Both inner rims were covered in grease and oil. I took the vent off and removed the spring and seal (no fording in the near future) and started to search of leaking axle posts here. The drivers side wheel was significantly more greasy/oily than the passenger side.
The pics show the inner wheel on the passenger side in one of the pics. The drivers side was 10x worse... I wold say at least 1/32in of grease/oil coating the inner wheel.
If you look at the pics the brake backing plate is dry, as is the outer hub. The fluid looks to have come from the open holes in the brake drum.. but the bottom of the backing plate is dry.
I plan to take off the drum to check brakes and remove the hub to repack the bearings.
Any other tips as to what the issue was?
