Leaking t-case seal
Hasdrubal
Vancouver BC
Had this issue with my rear output shaft seal for a while. Yes, I've replaced it 4 times. Lasts close to a year then starts seeping again. Eventually if I dont wipe it off it starts flinging off the yoke and drips on the ground, very small amount, buts its annoying. I have a 4 inch lift so the yoke is out about an inch from its stock position if that matters. Is there some kind of fix anyone here knows, like an oversize seal? I've heard of an ultrathin sleeve that can be placed on the shaft...would that be the way to go.
