- 1,222
- 2,188
- 113
- Wenatchee, WA
My fuel shutoff valve has 2 leaks currently since doing the dual fuel mod and loosening up the valve. The big leak around the threads I think I'll thicken up with teflon tape if those are pipe threads and if they're straight then maybe a new o-ring is in order. The leak at the shaft has me a little more concerned because I have not seen one of these disassembled and my valve doesn't look like the other ones I've seen so I don't know what's inside. I'm assuming that there is a little o-ring on the shaft that can be replaced? Has anyone seen an exploded diagram of just this valve?
