let off the gas truck shuts off
84cucv1ton
New Jersey
its a m1028. 4200 miles. pretty much new you would think. let it warm up. hit the gas quick and let off the it just shuts off?? what could that be??
Warthog
229
OKC, OK
Could be that you are using gas instead of diesel..................................Couldn't resist
Check you fuel return check valve on top of the injector pump.
coyote_hunter
Kansas
How long have you owned the truck? Did you recently put additive in the fuel? If so it may be the 1st time it was ever done causing the filter to be clogged.
kipman
15
Lancaster Ohio
Two stroke oil in the tank, run it like you stole it, if it has that few miles on it, it needs run, load it down, see what I mean?
