Lift Block Dimensions
shannondeese
High Springs Fl
What are the dimensions for the lift block when using M109 trailer springs to Bob a Duece. And where does everyone get thier U bolts for this application. Thanks.
Hammer
398
Winlock, WA
2 1/2" wide, to match the springs.
3 1/2" long to match the axle.
U bolts, someone local should be able to make them up for you.
Chinookpilot77
Enterprise, AL
Since the trailer axle is round and the truck axles are square, is anyone using a block on the bottom of the U-bolts to better mate up to the truck axle? Not a lift block, but more of a space block so the U-bolts seat better....just curious.
Hammer
398
Winlock, WA
If you put the U bolts on with the nuts facing down, you can just reuse the bottom plate from the deuce axle. It will locate the U bolts, and fits the axle well.
Or just get the bottom plate from the deuce front axle, so you have mounts for the shocks.
1,176
Is anyone using "store bought" lift blocks, or is everyone making their own?
Hammer
398
Winlock, WA
Even though I have some good lift block (the older SOLID ones), that would have worked well. I still made my own.
My reasoning is that I can weld my home made lift block to the axle. I also have tabs that extend down on the front and back of the axle (which is where I will weld them on). So they won't be able to move around like a normal lift block.
If you have the metal and tools, making the lift block is very easy, and will get you better results in the long run because of the added stability. MY 2 cents anyways.
