Lift pump hose
Chevykev
UK
Can anyone tell me the size of the rubber fuel lift pump hose ? Or a part number. I'm in the UK , usually use rockauto but can't find anything listed. Thanks
cucvrus
10,507
Jonestown Pennsylvania
What is a lift pump? Are we talking fuel pump on the engine? If so 3/8” /9 mm. I hope that helps. It is a formed hose but if you make it longer and make some gentle bends you can make straight hose work. I wrapped a few with split loom and wire tied them tight at the bends. It worked for years. Good Luck.
Chevykev
UK
Thanks. Yes the fuel pump on the side of the engine
