FrankUSMC
- 28
- 48
- Newport, NC
Looked at a Marine M35 that had two lifting brackets on it. The lifting bracket is the one that is between the two rear wheel assemblies. It is hooked into the side of the truck and pinned at the top of the rear springs.
So, how do I get them off? The pin does not go thought bracket like the pins for the shackels do. Is the pin welded into place or is it just a tight fit? Will a big hammer get them off?
Thanks for any help.
Not as lean, not as mean, but still a Marine. Frank
