Light All Terrain Tactical Vehicle
AttackMule
KC MO
Thanks for your heads-up comment--here it is! 950cc diesel 24VDC system. Equipped with 4WD, locking diff, run-flat tires, 17K BTU heater, lighting, gun scabbards, dump bed, 4K lb winch, and 30A 24VDC NATO single pin connector. Originally acquired in 2006 for security patrols, it had less the 700 miles when the front left hub disintegrated--after which it was idled for several years. It is now used for fence/boundary and outfall inspections.
AttackMule
KC MO
I acquired an AFPS-3215-24VDC 30A fuel transfer pump and a RAK-15 Water and Ration Heater for field use. I need to modify a cable for the RAK-15 before it can be used.
