- 1,579
- 541
- 113
- Greenback, TN
I have just picked up a light tower trailer equipped with an MEP-017A generator. Looking around on SS I don't see anything like it. My intended use is for radio communications so the lights have been taken off.
This is an older set, 1970. It has been painted white but is OD underneath.
Here's some miscellaneous data plate info:
Gasoline engine, Onan Division of Studebaker model SF-5.0-MD, TM-5-6115-332 (Engine built by Hercules, model 2A042, standard military engine.)
Trailer is “Floodlight set self-contained telescoping and Trailer Mounted Generator”.
Federal stock number 6230-181-2498
MFG part No: OG4-2/TMA
MFG S/N: 2581
CONTRACT NO: DAAJO1-71-C-0080(P1G)
DATE 12-70
WEIGHT 1850 LBS
International lighting systems
Division of Towtellite Corp
Sherman Oaks, California 91403
I have yet to try to run it because the oil looks like sludge so it's getting a new filter and oil first. Need to discover what filter it uses.....
This is my first question, what oil filter does an MS-35801 refer to? That number is on the filter housing but means nothing to a parts search.
I will post pictures soon but had to disassemble the trailer to haul it home.
Here are pictures of the load though! The generator is in the pickup, the little trailer is on top of the Unimog, and the tower is under the 'mog.
When it goes back together it will again be OD purty.
MFG S/N: 2581
DATE 12-70
WEIGHT 1850 LBS
