Celticlady
- 127
- 43
- Arkansas
Are your lenses glass or plastic?It is largely just bulbs, does it not light at all? I sell replacement lenses for them.
Plastic. No point in getting a lens kit as it was abused by previous owner. The circuit board looks like someone attempted to weld a chunk of 8 gage across one of the diodes. Circuit panel is trashed. I have the brake F/R press lights and parking brake switch light that's it.. Nothing else works Yes I can get the 373 and 376 bulbs at bulbtown for .45 If its just bulbs then I will need 22 of them. I looked at the circuit board and assumed the worst.Are your lenses glass or plastic?
My thoughts exactly. If I cant get a complete display Ill get a lens kit. My lens is toast.there must be thousands of these trucks scrapped!! my lens kit is plastic.
OK, And???I have one here
You should IM him.OK, And???
I have one here
How do I do that?You should IM him.
click on Suprnan's name under his Avatar. Then click "start conversion" Suprman aka.... Will is a well known vendor out of CT. good fellow.How do I do that?
You said you have a lens kit. I got a working display but the lens needs to be replaced. It is plastic. So is this kit a bezel with the lens or do I cut out the old lens and put the new in the bezelMy thoughts exactly. If I cant get a complete display Ill get a lens kit. My lens is toast.
