Limb Risers?????
McSpeed
293
Palmer, AK
Anybody have pictures or input on a proper limb riser cable/system for the M998?
I'm running a modified brush guard - but has the stock side windows around the lamps - so I can connect there.
Last time out this weekend we got on some really narrow trails and took a beating.
McSpeed
293
Palmer, AK
I just read a thread or two here and went looking for alternatives and came up with these. And…they work. I’d like to get stainless wing nuts on the adjusters to make it super easy to spin them on and off by hand.
TDButler
11
NJ
I’m using “rifle sling adapters” with metal d-rings for the time being, just an idea. I can release the Velcro and tension strap when I want to remove them. Only issue is they tend to slide after a couple hits (hence the zip ties).
McSpeed
293
Palmer, AK
That is awesome. Mine will get loose over a few hours on the trail even with it direct bolted. I keep a multi tool 10mm and can take out the slack or loosen to open the hood. If you scroll through some of my recent trail videos you will see at least the left cable bouncing bad towards the end of tue ride.
