TexAndy
- 15
- 38
- Bee County, Texas
One line appears to run from the air system "T" mounting under the dash. The other line appears to be a copper line running from a hole in the firewall.
I read in another thread that if you have a problem with gear oil venting through the lever, you should clean the transfer case vent and then disconnect one of the lines on the engagement lever to blow out any built up oil.
I cleaned and lubed the transfer case vent so it goes up and down and all around freely, now.
Which line do I disconnect, tho? The big air line coming from the "T" mounted underneath the dash or the copper line coming from the hole in the firewall?
Or both?
How does this system work, exactly? It *looks* like the lever is a kind of valve that when in the "out" position just blocks air from the air supply and in the "in" position directs air through that copper line running through the firewall down to the mechanism that engages the front axle. Which I suppose is why the line is copper. Am I correct in this thinking?
Or both?
