List of M56 Scorpion Parts needed for restoration
Austringer
34
Atlanta, Ga
Items Needed for M56 Restoration:
FSN / NSN Ord Part # # Needed Description
Engine:
12805-629-3058 62930581Cushion: power plant rear support
22805-797-527879752781Gasket: mounting, engine to transmission flange
Transmission:
16685-797-635679763561Unit, Sending: transmission high oil temp warning light
Hull:
12590-623-930287535306Lid, Ammunition Tube: assembly
22590-536-283787497772Box Assembly: grenade
387487544Handle
479997211Spring
579997201Spring
687487411Bracket
752661861Clip
Fuel Tank/Fuel System
12910-798-405679840561Cap: fuel tank filler
22910-571-678787491311Filter Assembly: filler neck
32910-592-243687497511Filler Assembly: fuel tank
42910-574-340787204161Pump: priming, fuel assy
52940-695-329777397641Jar: precleaner
61Sticker for above
75340-546-593187405681Coupling, Clamp, Grooved: air cleaner
84730-546-592687400594Clamp, Hose: air cleaner to tube
Exhaust System:
12990-602-577787530182Pipe, Exhaust: tailpipe
22990-571-6744874950510Gasket: copper, 2-17/64 id., 3-1/4 od, 0.010 thk
35340-571-683487493634Couping, Clamp: quick disconnect, exhaust pipe
42990-602-577683964992Muffler, Exhaust: complete
Gun Mount
12590-545-403187495831Pad, Crash: driver
22590-545-403487495871Pad, Crash: gunner
Driver Controls
187485401Handle
22530-798-023279802321Rod Assembly: flex., hand throttle control
32590-571-668187484881Control, Assembly: push-pull, parking brake latch
Electrical
170646041Connector Assy (accessories)
22590-591-583787410051Cable and Connector Assembly Electrical: radio power
35930-738-850673885061Switch Assembly: magneto
46220-735-371373537132Lamp Assembly
52590-571-662183793621Switch and Lead Assembly: horn
62920-546-590887406461Harness Assembly: instrument panel
75930-738-913273891322Switch Assembly: w/o toggle and cage
886927404Cushion
987493381Strap Assembly
102920-536-288187406331Harness, Wiring Branched: engine
Rubber Parts
12540-536-282087483932Boot, Dust and Moisture Seal: aelerator pedal
22530-571-668587484711Seal, Bellows: rubber, brake rod
32540-545-406087488081Seal, Rubber Angle: air inlet grille
42540-545-410287492574Seal, Rubber rear deck lid front
52540-545-411387492584Seal, Rubber rear deck lid side
Canvas Items
18749435Strap Assembly
22590-607-759987532201Boot, Dust and Moisture Seal: drain valve assembly
Seats
12540-536-283387409414Belt, Safety
22540-536-282787405382Seat, Indiidual, Equipment Operator
32540-571-664987499911Backrest Assembly: drivers seat
42540-571-664887499921Pan, Seat: w/padding, bonded, drivers
52540-536-282987405301Seat, Individual, Equipment Operator: gunner
Data Plates
12590-571-662987410561Plate: identification, transmission temperature warning
22590-571-662387410311Plate, Instruction: brake
32590-571-662687406121Plate, Identification: headlight beam indicator
42590-571-662787406211Plate, Identification: blackout selector
52590-571-662887406221Plate, Identification: horn switch
62590-571-663087406191Plate, Identification: master switch
72590-571-64961Plate, Instruction: Fire (gun fire lock)
82590-571-64951Plate, Instruction: Safe (gun safe lock)
Kyletelgen561
West palm beach Florida
Engine:
Transmission:
Hull:
387487544Handle
479997211Spring
579997201Spring
687487411Bracket
752661861Clip
61Sticker for above
Exhaust System:
Gun Mount
Driver Controls
187485401Handle
Electrical
886927404Cushion
Rubber Parts
Canvas Items
Seats
Data Plates
Hey just wondering if you or anyone you know has any rubber track sections for m56
