Domterry12
- 53
- 18
- New Jersey
As the title says, I am blowing little to no heat. Last winter I recall having decent heat, this year I pretty much have nothing.
Here is what I’ve done/checked before posting here:
antifreeze level is full.
Thermostat is in place, it’s the hockey puck style, and opened and closed in a pot of boiling water.
Removed return hose that goes from heater core to radiator, removed at rad and blew into it and was able to blow air thru it and the air was coming out at thermostat housing (stat removed)
Put back together, fired it up cold. No flow from heater core return line (was able to see with lowered antifreeze level) no flow until thermostat opened and then had good flow back into rad from heater core
Removed glove box and made sure heater box door was as far as it could go towards heat; even unscrewed cable and moved it as far as could go.
im stumped, any ideas?
