dbeasty
- 12
- 8
- Eastsound, wa
My 2003 LMTV A1 stopped starting.
Some history:
Generally it was starting like a dream, until the panel or electrical work was done on it.. ( this is the episode #2, the episode #1 ,., was diagnosed as loose battery cable, and supposedly the pushing in the fuses reset buttons..)
I was troubleshooting why the wipers, horn and sprayer do not work.
I opened the dash..,and what looked like turn signal connector and was trying to check P18 voltage per troubleshooting steps.
Now the connector plastic 3x4 was initially disconnected, and there was a 24 volts coming to what I concluded P18 aka 4 connector and 12 volts to #2 even though I did not hit any wiper function or the switch to start engine which is somewhat suspicious.
Anyhow I connected the the 3x4 connectors and the CTIS went to blink mode and bunch of more electronics went online and after that the LMTV decided not to start ANY more.
Objective:
I do not not want to turn in into another LMTV starting thread.
I can try to follow you troubleshooting steps from previous posting and the manual for A0.
Rather I would like to figure out what are the differences with the A1 vs A0 in terms of startup and troubleshooting for example how the ECU effects the whole process and how to take it out of equation and so forth.
Specific questions:
1. I would live to get a photo of A1 the fuse/relay panel diagram, since mine is somewhat warped and hard to read.
2. Would like to get an equivalent step for what I recall was K1 relay workaround to make the LMTV start. ( I do not think I do have K1 relay ), providing there is one..
3. I have a battery turn off switch next to batteries, but there is down below a dash a switch which seems to be next to ECU diagnostic CAT port, what is that switch for?
Some history:
Objective:
Specific questions:
