- 1,038
- 1,903
- 113
- Colorado
I figured I'd start this thread to nail down some options for PDP ice cube relays. If there's another thread with this info, please reference it.
I have the A1 so all my relays are 12v except for K1 and K2. Trouble is, if an LED fails on the PDP, I can't see if a relay is energized. This is happening for K26, the neutral relay of all things. Maybe happening for others. Obviously I could pull the board and re-solder a new LED into the board but that's annoying.
I found a source, HDSwitch, for the 30/40A relays (big 5 pin) that has an indicator light built in. On the truck, those relays are Tyco VF4-15F11-C05. The HD Switch is #115223705526. There's 8 of these in the PDP. So that's 1 type.
But I can't find an indicator type relay for the small 20A 5 pin relays like K26 which are Hella 4RD 931 524-02. There's 19 of these in the PDP.
That's the current progress.
