Questions for all ...
re M1078 series
How much height above the cab do you need to open up your rig? Or ... what is the absolute minimum height you need to open your rig before hitting an object above it?
How much weight can you add to the cab without over stressing the mechanical / hydraulic opening mechanism? I assume that this is in part dependent on the location of the added weight (think roof rack or AC versus floor and seat mods - and the difference in required torque).
How much weight can you add to the cab before having a negative effect on the air ride shocks?
re M1078 series
