FloridaAKM
- 395
- 83
- Gainesville, Florida
What is the finned connection under the hydraulic cab lock that the alternator cable leads go to & the cables come from the battery? There are several posts that the leads are all bolted to. The reason I ask is that the truck I have had the 24v lead come loose @ some time & it wore the threads off to where you could not tighten the leads back up! I have not found it in the TM's either!
