LMTV Oil change question with 3126B
reelclassic
Jacksonville, Florida
Changing the oil in my 3126B Caterpillar. Cat swears it holds 19 quarts. I'm at 21 quarts and nothing on the dip stick. Does anyone have an idea of what
it should hold. Looks like a shallow sump oil pan. Thanks for your help.
Suprman
696
Stratford/Connecticut
The military motors take more. 26 quarts maybe. I usually add till the dipstick is in the proper range. I give a few min for settling towards the end. Make sure your dipstick is going all the way in.
1,178
Is it listed on a data plate on the dash, like the earlier trucks are?
1,178
Found this, says 22 qts. http://olive-drab.com/idphoto/id_photos_fmtv.php
EngineCaterpillar 3126Heavy duty diesel, 6-cylinder, electronic controlled, fuel-injectedturbocharged and aftercooled, EPA certified
Rating275 hp (205 kW) @ 2400 rpm
Displacement442 cu in. (7.2 L)
Torque817 lb-ft (1,107 N.m) @1600 rpm
FuelDiesel, DF-2, JP-4, JP-8, VV-F-800
OilMIL-L-2104D, MIL-L-46167, 22 qt (21 L)
Are the TMs and Lube Order available for them?
