LMTV: Parking Brake Air Valve replacement
Pointman0853
13
Gardnerville, NV
I just purchased a new heater box for the Himars model from Will. It was suggested that I also upgrade the parking valve to one of the new dual modular units.
There is a lot going on in the new heater box and so much crammed in the left side.
Has anyone done this modification and are there any tricks involved? There seems to be a fair bit of plumbing down there and I would hate to muck it up.
On one of the brake threads there was reference to a write up, but I am having no joy locating that.
Pointman
Pointman0853
13
Gardnerville, NV
This is what I was looking for thanks NDT! One thing though.. At one point the new valve is shown with one port plugged. Later in the write up it was shown with two of the lower ports plugged..? Any insight would be helpful as I plan to tackle this this coming weekend..
Pointman
crcarson26
Reno, NV
Need A New Parking Brake Valve for my M1088 - Please Help!!
Can anyone tell me what the part number is on this Parking Brake valve?
Rig is a 1998 M1088. I have found a few new valves on eBay N4400B but it does mount the same and looks like the wrong part.
Please help!!!
Thanks,
coachgeo
3,394
North of Cincy OH
The duel type pictured will work as well.... just not as plug and play but cost can be good bit less even if you need ancillary parts to fit it.. "if it is on sale" which seems to happen every couple of months
jkcondrey
140
Rutherfordton, NC
I just spent some time replacing the trailer valve and have ordered the park valve. I will point out the Haldex recommended part # for the aftermarket is KN20035, as the replacement for the tm # n30262. I have seen the # listed kn20021 in some places, but the tech line and the website specify KN20035. I ordered the later and will note any issues when I get it here. The diagrams for this show a different updated knob style. There are differences on the haldex site between the -21 and -35 parts, specifically the push pull psi pressures. I am guessing this may be where Haldex recommended one over the other. However this is if you intend to replace each valve separately and not use the single piece valving system show a post or two up.
