LMTV Spicer bolt thread
mildoc
North Carolina
It appears the threads that the Spicer bolt/banjo bolt goes into are stripped. It looked like it was 5/8" 20thread but that still won't allow the bolt even to start. I looked up the 673998 specs and they don't seem to match up.
Any ideas to the bolt/thread size of this one?
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Take a picture of the location and what is stripped out on the truck. Some parts get different variants/ updates depending on WMOs or services done.
simp5782
9,339
Mason, TN
Other number for a coarse thread bolt is 673608. Dunno if those specs help you or not.
Your bolt you posted and the one being sold on ebay look similar in size.
mildoc
North Carolina
It is for the hose that attaches to the wheel for the CTIS. Where this hose attaches. This isn't my photo, I will take one of my wheel tomorrow but this is the hose I have. The old bolt was completely stripped of threads and barely holding in.
mildoc
North Carolina
It looks like just the first few threads are damaged. I will try to find a tap to see if I can clean them up and if not, then on to the next step.
mildoc
North Carolina
So here is the information I can pass on for the repair if anyone has this issue. Banjo bolt is 18mm 1.5 threads. A 16.5mm drill bit isn't easy to find but a 5/8 drilled it out for the tap. I'm not sure what hollow stud was in it before but there was no way it was even close to the 18mm since the 5/8 drill bit took a good amount of material before I cut the threads.
m-35tom
221
eldersburg maryland
here is another good tip, if you ever need a tap, NEVER buy one from NAPA. they are junk made in China and are not even close to sharp. Will not even work as a thread chaser.
CallMeColt
1,436
Wilson County, Texas
This is incorrect. It is not 18mm 1.5. It is 5/8 18 but not regular thread or NPT. I think it is ORB thread type but am still trying to figure it out myself for sure. ORB makes sense though since it is all made from hydraulic fittings.
