LMTV Trans not going into gear.
Thearmorystore
Grants Pass, OR
I have read a bunch of threads concerning my issue and none seem to be exactly what mine is.
I press drive and nothing happens. If I manually shift into 1st, it will move. Reverse works as well.
I had codes but they have now disappeared before I thought to write them down.
I am trying to help a friend out and move this thing off his property without getting a wrecker out here or driving 5mph down the highway
Thanks for any insight.
spankybear
980
WA
You can tell by the touch pad. The one with the single red LED number is the WTEC III. If you have the one with the 2 blue number display you have the WTEC II
Ronmar
8,326
Port angeles wa
Well the good thing about codes is it will store new current ones the next time you try and drive it. Go try it, read the new codes after it fails and write them down...
