LMTV Wiring/No Crank
95 Paul
LINY
Hi All
I'M working on a 2003 C40 LMTV with a Cat & Allison. Everything was working fine until the alternator went bad and burned up some wiring. I can get the truck started if we jump out the relay on the frame for the starter. The check transmission light is on the dash and have no crank signal going to the relay. Also we are getting signal from PTS to the K11 relay but no crank. Any one have a wiring schematic or direction of what to look at next would be helpful. We are think the TCM is bad, just need to know which wire is what.
GeneralDisorder
4,953
Portland, OR
Ronmar
7,191
Port angeles wa
Is k26 energizing With ign on? Thats the neutral start relay controlled by the trans. K26 powers K11, K11 when energized sends power to the start switches to allow engine crank using those switches as they feed the aux start relay on the frame… trans trouble may indicate something in the trans or its power feed is wrong and you are not getting the neutral start signal to power K26…
