Load Rates
Dave08
Titusville Florida
I have posted a thread on the M720 Dolly Set and requested to know if anyone can identify the difference between the HD and normal dolly as there is a 2000 pound capacity difference.
I need to also know whether you can use any dolly set to move any shelter? Meaning if a shelter is designed for the M720 dolly could you use the M832 dolly and vice versa? The manuals do not stipulate but they look as if they both attach the same way. Comments?
Dave08
Wolf.Dose
9
Boehl-Iggelheim, Germany
Make a long search shot.
A Dolly useually has a fivth wheel. This should be a standard (civilian) device. So the load of the fivth wheel useually is not the limit, the chassis below is the limit.
Hope this helps.
Wolf
SCSG-G4
PSVB 3003
3,320
Lexington, South Carolina
720 is a 3.5 ton dolly, 832 is a 5.5 ton dolly that has the same attaching points. 720 uses smaller tires than the 832 (832 uses deuce tires - 9.00 x 20). HTH
