Location of Climate Control Light Bulb
jplace1011
488
Santa Ana, CA
While digging around under the dashboard, I found this hanging bulb. It’s hanging down behind the Oil Pressure Gauge which is to the Left of the Voltmeter.
I’m guessing it’s the bulb for the climate control. There’s no light near the climate control. I’m assuming that because the bulb for the Voltmeter seems to be where it should be.
So what I don’t know is where exactly does that bulb plug into if it’s for the climate control?
I’m hoping I don’t have to take the dash apart and can just do it from underneath.
Thank you for any help.
jplace1011
488
Santa Ana, CA
I’m pretty sure it is on the defrost end and just twist lockers into place.
Update, I found the location for the Climate Control bulb!! Thank you for the info, that helped!!
As far as that hanging bulb, I discovered it goes to the Oil Pressure Gauge. The bozo mechanic who installed it never snapped the light into place!!
