Lockers, spools, open?
sermis
17
Temple, TX
Thinking about adding lockers or spools to the M35.
For the front axel I thought about a spool. Only time it would be used is off road. I have Overson lockout hubs so on road it would be unlocked. Any real advantages to using a locker up front over a spool if not used on road?
Rear axel I thought about a Detroit or Overson locker. ARB would be great but $$$
Also thought about a locker on the center axel but I am running an Overson lockout there to help with on road drivability. Might be a good place for an ARB in the future.
1,827
You might reconsider the spool on the front axle. Even off road you will need to steer and the front spool isn't going to allow that. With the Detroit in the front you can finesse it to steer, not with the spool. I wouldn't use the spool in any position unless you are doing some serious hardcore wheeling.
sermis
17
Temple, TX
No hardcore wheeling. Deep mud fun with the kids. Was thinking the spool would cause steering issues but was unsure. Spool would be cheeper than lockers.
TheBuggyman
Fredericksburg, Virginia
In our off road buggies with Deuce axles we weld the rear and put a Detroit in the front. The front Detroit allows you to steer when the front drive is not engaged. If you do put a spool in the front, which I would not do, you would need to put lock out hubs on the axle which would make it more expensive......
area52
San Bernardino CA
I have been rockcrawling for a few years and have not heard of too many people with spools up front. Steering in a decue without power steering is bad enough with an open diff, let alone with a spool. I say go with an ARB up front.
sermis
17
Temple, TX
Don't want some yuppe jeep to show me up with open dif's if I get in deep mud with the big ugly truck. Really don't want to get out in the mud to hook up the winch either.
BFR
Rocket Surgeon
2,330
42
North Georgia
I would want a detroit in the the rear and an ARB up front (at which point I would have more $$ in lockers than the cost of the truck). with the lockout on the center I would only use an ARB
1,827
FWIW, a Detroit Locker in the front will be invisible unless under power. Even woithout lockouts, you can run one in the front. You would need to learn how the Detroit works and adjust your driving accordingly when in AWD.
devilman96
17
Boca Raton, FL
Yep a ABR would be the thing for the front axle... Other wise and $ wise I would go with a locker, not a spool... As everyone says at least you can turn when your off the gas.
Elwenil
40
Covington, VA
Also with a spool, there is no way to relieve the stress of turning except for tire slip, which builds up stress and releases it suddenly only to build it back up again. This really fatigues the axle shafts and joints and will almost always eventually lead to a failure. The rock crawlers are breaking Rockwell shafts in fairly lightweight rigs, imagine what a full Deuce will do to one. I wouldn't use a spool or "Lincoln Locker" in anything and would only use a ARB, Detroit, or similar automatic locker.
